1949 Chevy Truck - Recommend electric cooling fan? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2013, 06:19 PM
I have a 1949 Chevy truck project. 350 engine with a new aluminum radiator. I don't have the clearance for a mechanical fan, even a flex fan and I will need to go with an electric fan or likely dual fans.
Any recommendations for an electric fan and shroud?
Old 06-04-2013, 06:36 PM
#1 18" T-brid fan from the mid 90's V-8 engines, also on some Lincolns
#2 17" T-bird fan, only used on the supercharged models in the 90's
#3 16" Taurus fan from the mid 90's on 3.8L engines, also used on 3.8 Lincolns
Old 06-05-2013, 05:25 AM
delawarebill's Avatar
fan
i'd sure get the biggest one that will fit.. look at the local parts stores.. i got one from NAPA a few yrs ago for my bucket.. it was like have a tornado attached to the rad..
Old 06-05-2013, 07:31 AM
Thanks. Have you found the dual fans to be better or should I just get the biggest CFM rating I can? What about the ones in Summit or Jegs magazines? Are they good or would I be better off going to NAPA?
Old 06-05-2013, 05:29 PM
fan
lets just say... napa has a warranty and so do jeggs/sumitt. who is easier to return to.. but i will add that when i got mine i was at the ocean city md cruise and my fan with out.. i had little choice.. but again the fan was great.. how bout pep boys too.. or any local parts store for that matter.. i had mine on a on/off sw so i ran it all the time..
Old 06-05-2013, 05:42 PM
I will give that a try. Can you order them buy dimensions and CFM rating at NAPA or do I need to reference a certain vehicle?
Old 06-06-2013, 07:08 AM
fan
just measure the core of the rad.. the fin'd area. and start looking.. the parts store will have size/cfm, but the sumitt/jeggs will have by veh also.. for me i'd just be looking for the largest in size and cfm and if u have a clearance problem that too.. they are reversible by changing the power line from one to the other. u really want a puller install..
anyone recommend a thermostat for electric fan? Studedean Electrical 4 01-12-2012 12:19 AM
electric cooling fan tbrown8338 Hotrodding Basics 3 10-14-2011 03:26 PM
electric cooling fan? sexypizzaman Engine 18 02-14-2008 09:17 PM
electric fan on chevy truck 350 ? briansansone Electrical 8 01-06-2006 05:06 PM
cooling with an electric fan? hotrod66_57 General Rodding Tech 11 08-14-2004 09:41 AM
