Thread Tools Search this Thread share on Facebook
  #1
Old 02-04-2012, 01:09 PM
rambler454's Avatar
rambler454 rambler454 is offline
Last journal entry: updates
Last classified ad: no title
1949 dodge
i chopped the room 4 inch's because if you ever seen one of these truck you would think they was built for a giant. the roof was ignorantly high so i chopped it. well it was a 2 peice windshield and i dont want to got back with that style. it has a metel divider in the middle. i want the get the right glass and has it bent to the shape of where the windshield would go like bend it where the two would original of met in the middle. how and where would i get glass work done like this?
Register now (free) or login to remove ads
Old 02-04-2012, 01:32 PM
poncho62's Avatar
poncho62 poncho62 is offline
Last journal entry: 51 Ford F1
Wiki Edits: 5
The way they used to do that was to butt 2 pieces of glass together and bond it with epoxy.......
In the words of Walter Cronkite..."And that's the way it is."
Ontario Rodders
Old 02-04-2012, 05:44 PM
rambler454's Avatar
would the seam be clear?
Old 02-04-2012, 09:43 PM
27Tall T 27Tall T is offline
The trick is to grind the glass at an angle so that when you apply the silicone there is very little that is making the seal. I've seen glass that was squared and butted with silicone leaving almost 3/16"-1/4" of silicone showing. You will always see a line there, but it depends on how much time you take to make it fit reasonably.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1949 dodge"
ThreadThread StarterForumRepliesLast Post
1949 5 window dodge truckkonicaHotrodding Basics508-26-2011 04:29 AM
1949 Dodge pu 1/2 ton.redneck1949Introduce Yourself205-17-2011 05:52 PM
Lowering 1949 Dodge P/UonebaddladSuspension - Brakes - Steering1012-17-2007 06:56 PM
New member 1949 Dodgelil79redIntroduce Yourself212-12-2007 05:12 PM
dodge pilot house 1949ajb4266Introduce Yourself307-05-2006 02:29 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
