1949 dodge b1b truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2012, 11:57 PM
What is the size ratio in a 1949 Dodge B1B truck? Looks like a 8 3/4 but thety did not come out till the mid 50's.
Old 08-13-2012, 05:36 AM
just starting a 49
here is a link to the site i use to get all the info you will need to work on that truck Pilot-house Truck Knowledge hope this helps
Old 08-13-2012, 05:48 AM
more info
from the book could be 3.73,4.1,4.3,or4.78 to know look at diff. just under the fill on the passenger side bottom should be stamped in the diff hub
Old 08-15-2012, 08:04 PM
1949 B1B RearEnd
The ratio is 4.78 . Does a 1948 plymouth rear end fit? Plymouth is A body and the doge truck is B body. The measurements are off less than 1". Not sure about the ange of the bird perch?
Old 08-17-2012, 06:42 AM
Axle Type Semifloating
Differential Hypoid
Differential Ratio 3.90
Old 08-17-2012, 06:45 AM
after looking up 48 Plymouth with some mod it will work with a 3.9 ratio it will help you will need to move the spring on the rear end to reset the angle
1949 dodge rambler454 Hotrodding Basics 3 02-04-2012 09:43 PM
1949 5 window dodge truck konica Hotrodding Basics 5 08-26-2011 04:29 AM
1949 Dodge pu 1/2 ton. redneck1949 Introduce Yourself 2 05-17-2011 05:52 PM
1949 Dodge five window truck frame swap TreeTop Hotrodding Basics 14 10-28-2010 12:07 PM
Lowering 1949 Dodge P/U onebaddlad Suspension - Brakes - Steering 10 12-17-2007 06:56 PM
