1949 flathead head bolts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2006, 09:34 AM
northernhillbilly's Avatar
I am wondering if using grade 8 bolts for temporary head bolts is ok on a 1949 ford flathead?
Old 07-04-2006, 11:51 AM
woodz428's Avatar
Troll Hunter
A grade 8 bolt will more than serve the purpose. Why did you say temporary? Are you going to get studs?
Old 07-04-2006, 04:47 PM
I've got the real head bolts on order and I wanted a temprary fix( to move the truck aroud to do other work) Thanks for the info. I'm running stock heads so no studs, but when a pair of alum. heads come my way for sure.
Old 07-04-2006, 06:33 PM
351W heads, how to identify from 289/302 RAW Engine 22 01-28-2010 03:54 PM
SBO 350, Head Gasket help, with photos 360Camaro Engine 5 07-11-2005 08:29 PM
5.0 head bolts oldred Engine 4 12-18-2004 09:09 PM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
