Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1949 Ford F1
Thread: 1949 Ford F1
Old 01-02-2013, 10:58 PM
crownver crownver is offline
I meant if you put the leaf springs below the axle on the front you might run into clearance problems. Dropped axle is the way to go. I might try to drop the axle myself, like this SUSPENSION, Dropping axles - THE H.A.M.B. if I work up the courage!
