1949 Ford F1 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2013, 08:20 PM
1949 Ford F1
Hi i am new to this site and have a 49 F1 and want to install power steering and have heard the Toyota gear box works well, also want to lower the truck any suggestions and info?? I already own a Toyota 4x4 for the donor gear box and am using the stock F1 frame.. thanks
Old 01-02-2013, 09:04 PM
Here's a site with information on the steering box switch.
Toyota Steering Box Swap For 1948-1960 Trucks .: Articles
Biggest problem is the pitman arm. There is a kit available here
Mid Fifty F-100 Parts - Search
with everything you need. The Ford site is a good one for info on dropping your axle.
The Following User Says Thank You to crownver For This Useful Post:
ajatruck (01-03-2013)
Old 01-02-2013, 09:13 PM
I have a '50 F47 (Canadian F1) that I hope to start 1 day. I plan on dropping the front axle, and using an Explorer rear with the springs mounted below. You can do the same with the front axle but you might run into clearance problems. I've got the steering box and the rear end, but that's as far as I have gone.
Old 01-02-2013, 09:14 PM
Thank you for the info!!! Any help is great!!!
Old 01-02-2013, 09:24 PM
What kind of clearance problems do you think I will run into? Want to go with about a 3 inch drop axle and the Toyota steering with a total disc brake conversion!!
Old 01-02-2013, 09:58 PM
I meant if you put the leaf springs below the axle on the front you might run into clearance problems. Dropped axle is the way to go. I might try to drop the axle myself, like this SUSPENSION, Dropping axles - THE H.A.M.B. if I work up the courage!
Old 01-02-2013, 10:02 PM
If you use a Ford Exporer axle you can get it with posi and disc brakes. Gives you a 5 on 4.5 wheel pattern so you can go with the same disc brake kit for the front.
Old 01-02-2013, 10:34 PM
I heard that too!! Do you know what year explorer axles work for this?? I am guessing the smaller older explorers like 03 and older, not sure the year they went with the bigger body!! Thanks alot for the info!!!
Old 01-02-2013, 11:30 PM
For disc brakes you'll need a 96 or newer Explorer rear. Bear in mind I haven't put it in yet, but I know there'll be some cutting and welding involved to make it fit. It's not a bolt in. Here's a good article from Ford Truck enthusiasts that's good reading. About 1/2 way down there's info on Explorer rear ends.
1948 through 1960 Ford F-1 and F-100 Rear Axle (differential) Swaps .: Articles
Old 01-03-2013, 02:30 PM
Thanks for the info!!! Its great reading!!
1949 Flathead Ford rdk inspect Engine 3 06-17-2011 06:14 AM
1949 Ford Coupe speede5 Hotrodders' Lounge 7 03-22-2009 08:34 AM
1949 ford f1 truck drsergio Introduce Yourself 4 03-19-2008 07:20 AM
1949 Ford F1 mw1151 Introduce Yourself 1 06-26-2007 11:06 AM
