1949 ford f1 truck lowering .......... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2008, 03:32 PM
Ok Here is the question
I have a very original truck ( pictures on the gallery 1949 ford f1)
Original 650 /16 bias tires.
Would like to replace the rear with 275/60/15 and front 195/60/15
that will lower the truck a little
They will go on cragar ss rims
I woudl like to lower the front a little more but I would like to keet as close possible to stock.
Can I just get shorter springs and new shocks?
would that do it?>
what about the back? any tricks?
maybe I am all wrong ,,,,,thats why I need Help
Thank you so much for any help or suggggggestion !!!!
Old 03-18-2008, 06:09 PM
BLACK I love it.
Most competent spring shops can de-arch your springs and lower the truck. I suggest that route. You remove the spring pack and they change the arch of the springs. If you are industrious, you can just remove a few of the leafs and accomplish the same thing but the load carrying capacity will be reduced ( but the ride quality improved ).
Also, there are places who drop axles ... they take your front axle, heat it and stretch it ... while maintaining the proper caster . I had this done to both a 49 F-1 ( not as nice as yours but much quicker SBC/4 speed ) and a 56 F-100 big window.
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
1949 F1 S10 frame bcovey Hotrodding Basics 21 12-15-2008 09:43 AM
Amazing Discovery about Ford F1 Gauges. lakota Hotrodding Basics 6 12-19-2007 12:44 AM
51 Ford Panel Truck BAD TO THE BONE 413 Introduce Yourself 4 01-02-2006 06:38 PM
66 ford truck swapping a 240 i6 out for small block chevy igotachevyor2 Engine 0 04-14-2002 03:19 PM
