Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1949 International !/2 ton
Old 08-26-2003, 07:03 AM
Centerline Centerline is offline
Wiki Edits: 49
I doubt if your going to find a kit for your truck simply because its not one of the more "popular" models around.
I would take some measurements off the front section of your frame (frame width, length, tire track width, etc.) and take a look at some of the more popular frame clips (Nova, Camaro etc.) to see if one might come close to fitting. Another option might be the bolt on system used in mid 70's Chevy pickups. Depending on your ingenuity you might be able to make one of those setups work.
Good luck
Centerline
http://www.hotrodsandhemis.com
