-   -   1949 International !/2 ton (http://www.hotrodders.com/forum/1949-international-2-ton-21935.html)
KDP 08-25-2003 08:39 PM
I have a 1949 International 1/2 ton p/u and I am wanting to put a independent front suspension on it and was wondering if there is any kits out there and if not are there are any ideas how I it could be done.
Centerline 08-26-2003 06:03 AM
I doubt if your going to find a kit for your truck simply because its not one of the more "popular" models around.
I would take some measurements off the front section of your frame (frame width, length, tire track width, etc.) and take a look at some of the more popular frame clips (Nova, Camaro etc.) to see if one might come close to fitting. Another option might be the bolt on system used in mid 70's Chevy pickups. Depending on your ingenuity you might be able to make one of those setups work.
Good luck
Centerline
http://www.hotrodsandhemis.com
TooMany2count 08-26-2003 11:39 AM
http://www.chevytrucks.org/tech/ifs&rearend.htm this site has all kinds of info on different suspensions. It should be just what you need...........joe
V8 S-10 08-26-2003 05:59 PM
I have a old StreetRodder mag that showed them putting a S10 clip on a late 40s international. I'll see if i can dig it up/
