195 PSI 10.3 to 1 compression on street fuel - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2010, 06:23 AM
Hey! what are your thoughts on running a motor on pump super with 195 psi compression and 10.3 to 1 ratio?
Old 08-07-2010, 07:58 AM
depends what engine and heads and load. what engine are you talking about? What car? do you plan to pull a trailer? what gear and trans?
If it is a 454 with stock iron heads then I would say no.
if it is a 350 with flat tops and vortec iron or aluminum heads then I would say, no problem with 93 octane.
If it is a 1100cc honda then it would be ok too.
some of things that effect octane requirement are flame speed, piston diameter, head material, head chamber design, and others.......
10.3:1 cr with 195psi of cranking pressure means the cam is fairly mild.
would require 93 octane in most cases.
Old 08-07-2010, 11:21 AM
If its a dohc pent roof chamber then you could probably run 87 octane as a lot of oem's recomend that.
Need more details.
compression ratio and fuel confusion 55effie Engine 14 03-19-2010 08:00 AM
Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines J.J. LASALLE General Rodding Tech 6 06-29-2009 01:04 AM
high presure fuel pump and fuel injectors ( 300 psi) remcolent Engine 4 08-27-2007 07:36 PM
Holley Street Avenger Fuel Line western star Engine 5 12-30-2003 09:25 AM
Street Avenger 670 fuel line? western star Engine 4 11-23-2003 03:37 PM
