1950 chev pickup - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-26-2003, 08:19 AM
Rockettruck's Avatar
Smile
I regularly drive my '51 with a '74 Nova clip and it works great. We installed the clip in 1988--I've owned the truck since 1976. I also am finishing up another chassis with the same kind of clip for use in a 1/2 ton panel.
Yes, the subframes are a lot of work, but if you can do your own fabrication they can be cheaper. A key point here though is to start with a sub that already has disc brakes and power steering. Yes, you can add those later, but it really drives the price up.
Another alternative would be a pre-fabricated subframe that uses Dodge Dakota (!) suspension components. It's kind of pricey but it looks like it would do the job very well. It's made by a company called Industrial Chassis out of the Phoenix area.
Just FYI...
Rockettruck
  #17 (permalink)
Old 11-27-2003, 08:47 AM
Thumbs up 50 -CHEVY TRUCK!!!
WE HAVE TWO 50 CHEVY FIVE WINDOW PICKUPS. ONE IS REALLY NICE ALL STOCK WHEN I FINISH UP THIS ONE, IT WILL BE A HOT STOCKER!! WE HAVE THE FENTON HEADERS,INTAKE MANIFOLD FOR TWO CARBS, NICE FEN-TON ROCKER COVER + SIDE PLATE. THIS A 261 SIX MOTOR. MAN YOU SHOULD HEAR THIS WITH TWO SMITTY MUFFLERS !!!!! IT WILL RAP LIKE YOU WILL NOT BELIEVE!!!
FOR OUR OTHER TRUCK WE WILL BE WORKING WITH CHRIS ALSTON AT THE CHASSISWORKSWWW. CHASSISWORKES.COM, I HAVE KNOWN CHRIS FOR A LONG TIME & HE MAKES GOOD THINGS!!!!
WHAT WE ARE BUILDING IS A CHASSIS FROM CHRIS , A FULL CHASSIS READY TO GO~ JUST PUT YOUR MOTOR , TRANS,DRIVE LINE , TIRES & WHEELS~ YOUR FINISHED BODY ON, HOOK UP THE WIRES & GO.
ON OUR TRUCK WE WILL HAVE A SET OF M/T TIRES ( 14') A HOT 327 WITH A SMOKEY RAM ON TOP, MANY A TILT HOOD ??T-400 TRANS. YOU CAN BUY A FULL SET UP FOR AROUND $6000.00+- ?
ANY TIME YOU TRY TO BUY ANYTHING FROM A VETT IT COST $$$$$$ MORE THAN A NEW ONE!!!!!
HOPE THIS WILL GET YOU ON THE ROAD & DO A SUPER GOOD JOB ON THAT BODY!!
NORM
  #18 (permalink)
Old 12-02-2003, 11:10 AM
New Member
How about a rusted gas tank
The gas tank needs some serious rust removal. Are there any tricks? Someone mentioned once that they actually cut the tank open, clean it out, and weld it back together. Thats ok as long as they don't try it in my shop - KABOOM!!
« Hi y'all | testing »
