Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1950 Chev Truck - What Frame, Suspension, and all to use?
Old 11-26-2011, 08:08 PM
MARTINSR MARTINSR is online now
Originally Posted by NEW INTERIORS
The reason I Like a new frame is.. For one everyone usually want's to box their frame,,
Well !!!
if your going to go through the trouble to do that... Just use tubing,,
Much easier,
and if your also wanting to add a Mustang II,, Much easier,
Then... If you want it to sit low.. You can zee the frame rails while your at it..
So by doing a new frame you can get a lot of good things from doing it new... Back to it's all in what you want from it.. The list can go on and on..
If your looking to put a nice motor and like the look of a box frame... The truck frame is so easy to just use tubing to do the frame,, Straight runs.. Very easy to do... If your not looking to Zee the frame any..
I'm with you if you want all that, heck yes making a new one would be easier. That is one of the great lies about frame swapping, that frame was SOOOOOOO simple, it had such basic shape. You could make it very easily, even a first timer could make one easier than swapping in a modern frame that is way more complex in shape.
