1950 Chevrolet 3/4 ton 3600 series
I know it is difficult to find parts for the huck brakes but i am in need of the toggle arm for the left rear. the toggle arm is approx. 5/8 in.n diameter is is threaded on one end, which the threads go through the front brake shoe, has a 90 degree bend alond with subsequent bends to end with a forked end. There should be a "L" stamped near the forked end.
The purpose of this toggle arm is to force the front brake pad against the brake drum when the emergency brake is applied. Also I am in need of a right front spindle for this truck. |
1950 Chevy 3/4 ton 3600 series
If you can help me with these parts e-mail to magicdonduck@sbcglobal.net
50 chev
ive had pretty good luck getting older cev parts from ecklers out of fla. i found wheel cyl kits and tapered front wheel bearing for 1950 chev car. i also found emergency brake parts for 1955 chev.
:welcome:still looking.:sweat:
| All times are GMT -6. The time now is 08:01 PM. |
