1950 Chevrolet 3/4 ton 3600 series - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2012, 07:14 AM
I know it is difficult to find parts for the huck brakes but i am in need of the toggle arm for the left rear. the toggle arm is approx. 5/8 in.n diameter is is threaded on one end, which the threads go through the front brake shoe, has a 90 degree bend alond with subsequent bends to end with a forked end. There should be a "L" stamped near the forked end.
The purpose of this toggle arm is to force the front brake pad against the brake drum when the emergency brake is applied.
Also I am in need of a right front spindle for this truck.
Old 10-31-2012, 07:16 AM
1950 Chevy 3/4 ton 3600 series
If you can help me with these parts e-mail to magicdonduck@sbcglobal.net
Old 11-09-2012, 05:43 PM
50 chev
ive had pretty good luck getting older cev parts from ecklers out of fla. i found wheel cyl kits and tapered front wheel bearing for 1950 chev car. i also found emergency brake parts for 1955 chev.
Old 11-09-2012, 07:10 PM
still looking.
Will 1950 Chevy 1/2 ton pickup parts fit a one ton of same year? Hunt89dan Hotrodding Basics 3 06-11-2012 09:06 PM
chevy 1950 3/4 ton to 1/2 ton solid axle swap 3/4ton flathead Suspension - Brakes - Steering 5 02-20-2011 07:58 PM
54 Chevy Series 1 3600 Pickup Old Surveyor Introduce Yourself 2 02-07-2011 03:10 PM
54 chevy Series 1 3600 front wheel hub Old Surveyor Suspension - Brakes - Steering 1 02-06-2011 08:36 PM
55 chevy 3600 3/4 ton project begins heavychevy55 Introduce Yourself 2 06-05-2010 09:27 PM
