1950 chevy swap to s-10 frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2007, 05:09 PM
Hello im was woundering what model of s10- should i look for to swap my 50s model chevy 3100 to?
Old 09-17-2007, 07:15 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders. Best to ask in the General Hotrodding Tech forum. But you need to get one that has a track width and wheelbase that is the same as the body that you are going to put on it. Frame swaps rarely are easy.
Old 09-17-2007, 09:33 PM
Some of our members have done this swap I may do it in the future I like these trucks too
You can make or modify the brackets and mounts needed yourself or buy them at
http://www.ad-engineering.com/
Shane
Old 09-24-2007, 07:23 PM
94 4x4 blazer
Hello again sorry been away for awhile, but does anyone know if a 94 4x4 4 door blazer will work for my swapping project? im wanting to swap my 50 chevy pickup cab and bed to a later model frame. hopeing maybe this will work. Please let me know. Thanks
Old 02-28-2008, 01:15 PM
Hi, the original wheel base of your truck is 116 inch. It will fit on a S10 frame ( 118 inch wheel base) with very minor modification .Just check ad-engineering website, you will have all the answer about it.
Old 03-08-2012, 08:49 PM
Dead ahead Ed
Dead Ahead Ed
You will need a single cab long bed S10 for the simplest swap. An S10 4x4 rear axle will get the rear tires away from the bed. 2 inch back spaced rims in the front will get the tires outboard. The weight of the 50 Chevy truck and the S10 are both 3100 lbs. The long box or long bed single cabs are getting scarce. It was easier for me to buy a used S10 than get the rolling frame from a salvage yard and cheaper, too. I'll sell or scrap the S10 body to reduce the costs of this project. Good luck.
Old 03-10-2012, 07:06 AM
Thanks for the reply.
1950 chevy truck/S10 chassis swap kbangs1 General Rodding Tech 4 05-31-2012 11:53 AM
Brake lights switch oldsmo Electrical 4 10-19-2006 11:23 AM
frame swap? chevy13 Suspension - Brakes - Steering 2 02-19-2006 11:18 AM
55 frame swap 55twodrpost General Rodding Tech 2 04-13-2005 01:41 PM
