1950 Chevy Truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2011, 04:17 PM
Last journal entry: 1950 chevy 3100 P/U
1950 Chevy Truck
I am working on my 1950 chevy truck and was wondering what the best rear end would be for it. I am planning on putting a small block engine in it. any help or infor would be greatly appreciated.
Old 10-05-2011, 05:42 PM
Wiki Edits: 49
Mid 70's Camaro or Firebird. The are within an inch of being the exact width of your stock axle and are still fairly plentiful. Here's my '53 chassis with a 78 Firebird 10 bolt rear end.
Centerline
HotRodsAndHemis.com
"Moonshiners put more time, energy, thought, and love into their cars than any racer ever will. Lose on the track, and you go home. Lose with a load of whiskey, and you go to jail." Junior Johnson
Old 10-06-2011, 04:31 AM
A 6 lug 1/2 ton axle from a 67-87 will fit nicely if there's a need to retain the original wheel bolt pattern.67-72 axle is just about the same width.I used a 73-87 type 1/2 ton 4x4 axle in my 50 Chevy PU.It's two inches wider but fits nicely.The earlier axles are truck 12 bolts,most 73 and up are 10 bolt.
Old 10-18-2011, 12:27 PM
Centerline
HotRodsAndHemis.com
Is that a Mustang II IFS on the front of your frame?
Old 10-18-2011, 10:17 PM
Wiki Edits: 49
Yes. Heidts Mustang II IFS with the big GM disk brake kit and power rack.
Centerline
HotRodsAndHemis.com
Never pick a fight with an old man. If he is too old to fight, he'll just shoot you. - Anonymous
Old 01-12-2012, 09:55 PM
did u have 2 do any mods 2 the rearend 2 place it in place.
do u have and picture of the rear
Old 01-15-2012, 07:00 PM
the spring perches have to be changed. jegs or summit racing should have them.or any 4wheel drive shop.
Old 01-15-2012, 08:38 PM
Wiki Edits: 49
Actually I used the rear springs from a Dodge Caravan and moved the front mount outboard of the frame to make the springs parallel. Doing this did not require any changes in the spring perches and it lets the springs work properly.
You can see how I built this truck on my web site.... link below my signature.
Centerline
HotRodsAndHemis.com
"Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen
Pictures of 1950 chevy truck chevykid33 Hotrodding Basics 3 02-23-2011 10:02 PM
Rear end for a 1950 Chevy Truck chevykid33 Transmission - Rearend 9 02-19-2011 09:52 PM
1950 chevy truck front hub Dave Cauble Suspension - Brakes - Steering 1 09-19-2010 01:48 PM
1950 Chevy Truck DC50Chev Introduce Yourself 2 09-01-2007 07:58 PM
ChopTop 1950 Chevy Truck efland07 Body - Exterior 4 11-28-2005 08:47 PM
