1950 chevy truck 6 cylinder 216 engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2010, 03:58 PM
I have a 3100 50 chevy truck with a 216 engine. I am just starting to restore the truck. What causes the sparkplugs to be completely coated with black and black spatter to be emitted out the exhaust pipe?
Old 07-06-2010, 05:44 PM
very rich mixture
Old 07-06-2010, 07:44 PM
poncho62's Avatar
Wiki Edits: 5
Are you driving the truck or is it just sitting and being run occasionally and just idled when it is?
If thats the case, it could be that the plugs are fouling, bad gas, carb getting plugged up........
Ontario Rodders
Old 07-07-2010, 12:41 AM
Wiki Edits: 31
running rich. fuel distrobution on a 216 really isn't great ( exhaust heated manifold ) so when there colder, they will run a little rich, and having an older carb that probably needs a rebuild won't atomize the fuel as 1 that has been rebuilt
Old 07-25-2010, 02:02 PM
QParker's Avatar
Six Offender
could be really old gas containing lead where the lead has settled to the bottom so you're burning more lead than fuel. Does it rev up (above around 2500) if so it's not the lead, listen to the other guys...
Old 07-25-2010, 03:05 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Black is carbon. Carbon is most often formed in an engine's combustion chamber (and therefore on the plugs) because of incomplete burning of the air/fuel mixture. This can be because of a lot of things, but usually will be a too-rich a/f mixture caused by a bad or incorrectly adjusted carb and/or choke.
The black spatter from the exhaust system is this same carbon being ejected along w/either fuel, coolant or more likely water from condensation that forms in the exhaust system by running the engine below the operating temp.
Old 07-25-2010, 07:45 PM
LATECH's Avatar
Last journal entry: New Gas Tank
yup yup yup... running rich + flooding . Rebuild the carb
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
new engine for a 29 chevy truck Rockafellow Hotrodding Basics 3 08-23-2005 12:40 PM
429 caddy moter in 1950 chevy truck ?? cool running Engine 3 05-20-2004 05:45 AM
12 bolt rear for a 1950 chevy truck solowookie Transmission - Rearend 3 11-17-2002 08:45 PM
spring selection for a 1950 chevy truck solowookie Suspension - Brakes - Steering 4 03-19-2002 10:21 PM
