1950 chevy truck front sub frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2006, 05:27 PM
1950 chevy truck sub frame
Hey all,
I still am tring to decide what subframe to use on my 1950 chevy truck. I have been told that a GM "G" body would work great. A book said to use a Rear steer model?? I think its talking about steering gear box location but not sure. any help would be great. Also, is there any videos or books or guides out there to use? Thanks in advance for the help.
Last edited by LNOVA; 04-23-2006 at 04:22 PM. Reason: Thank you guys for the help!!!!!
Old 04-20-2006, 06:21 PM
Wiki Edits: 49
For my money a Mustang II IFS would be easier, faster and in the long run wouldn't cost any more. But that's my money.
Rear steer refers to the position of the rack unit.
Old 04-21-2006, 05:31 AM
Originally Posted by LNOVA
Hey all,
I have read about using an S10 maybe that is a G body picked up a 86 longbed s10- for the project will see when I find the time E dke6bnl
Old 04-21-2006, 11:48 PM
Rick 5150 69's Avatar
G-bodies referance to buick / olds `81-87 front sub frames are 2 inches narrower at the control arms, better suited for sub frame graft, rear steering box meaning it is behind the front crossmember as opposed too being in front of it!
Old 04-22-2006, 12:17 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
LNOVA here is a link from this site to an article on a bolt in ifs for your truck.
http://50chevy.freeservers.com/Bolt_...pendent_2.html
There is also a kit to bolt in the S10 suspension but I can not find my link. Someone else on this site has the link and will post it if they see your post.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 04-22-2006, 08:27 AM
Wiki Edits: 49
That system will work but take a close look at the position of the tires. This IFS is too wide and the tires will rub the fenders. The only way to fix that is to use special order wheels with "odd ball" back spacing.
Old 04-22-2006, 09:02 AM
I have herd of people cutting out the center of the cross member the approprate amount and welding it back to get the correct width. Ed ke6bnl
Old 04-22-2006, 10:25 AM
50 chevy p/u's Avatar
autoglass master tech
I used a 69 camaro subframe on my 50 chev. Did the overlay technic.
Here's the link for the s-10.
www.ad-engineering.com
Name:	front of frame.JPG
ID:	11733   Click image for larger version
Name:	rear of frame.JPG
Old 04-22-2006, 09:55 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
Hotrodders Bulletin Board post.
suspension widths
....joe
Old 04-23-2006, 09:15 PM
i went with a jag front clip so far not to bad but not done yet
Old 04-29-2006, 02:43 PM
1950 chevy truck subframe
I think I found a donor car for a subframe. Its a 1979 olds cutlas, it is a v8 car. The tires seemed to have normal wear, I hope that means the components are good. What do you guys think? a good choice? the yard is selling it to me for $100.00. any advice would be great. Thanks!!
Old 04-30-2006, 09:27 AM
If it was me, it would be home by now, do all your measuring four times, cut once, weld in, then rebuild all the wear items!
Old 04-30-2006, 10:50 AM
I posted this question in the intro secetion by mistake, sorry still new in here. Anyway, I am buying a 1979 olds cutlas for the front sub frame. It is a V8 car. I have never done this type of swap so any advice would be great. Any of you guys that have done this on a truck like mine could you please share the details about how you did it. Also, is this doner car a good choice? I know this is a much talked about subject in here but the more I can learn the better.
Thanks in advance for the help!
Need some help about my 1967 chevy truck frame 67Chevy_c10 Body - Exterior 4 03-17-2006 05:56 PM
front end help on 85 chevy truck digitalfrek Suspension - Brakes - Steering 1 10-02-2004 08:04 PM
4 link for stock 67-72 chevy truck frame 68c10owner Suspension - Brakes - Steering 2 09-11-2004 12:04 PM
51 chevrolet truck on a chevy S10 frame Bronco226 Introduce Yourself 2 08-26-2004 12:36 PM
66 chevy truck frame swapping ezoo Suspension - Brakes - Steering 9 01-13-2003 04:58 AM
