I have a 1950 chevy 1/2 ton body that I want to make a street rod out of. It came with an 80's S10 frame but unassembled. How do I get basic chassis specs for the 50 chevy - stock wheelbase, track width, cab location from the centerline of the front balljoints, etc.. Any help would be appreciated.
Thanks Kurt |
The reason it came unassembled is that the guy you bought it from screwed up and couldn't get it together and passed it on to you.
The dimensions you seek are probably not to be found except by someone on this site doing the work and passing the info on to you. That's where you're lucky; these guys are very very helpful! Someone here may even have attempted or succeeded in doing what you're trying. In general it is easier to use the old car/truck frame and add more modern components to it than to rebody a modern frame. Trucks are easier since the floor area is relatively flat and the bed sits on blocks anyway, but you still have to contend with wheelbase, track, and manufacturing the braketry to hold up your front sheet metal properly and so on and so on. Best of luck! |
Pasadenahotrod is right. The Stovebolt forum has had several discussions on this swap and no one over there thinks its a good idea for a couple of reasons. First the S-10 chassis is too narrow and too long, and second the kickup of the rear frame makes the stock bed almost unusable. Keeping in mind that those guys are pretty knowledgable about these trucks that should tell you something. However the majority of them prefer restored trucks so their may be some bias in that direction too.
One thing I've read everywhere on this swap is that it isn't easy and is a lot of work. In your case you probably have no choice since the only frame you have is the S-10 that came with the cab. If you have to do this swap pick up the current issue of this magazine. <a href="http://www.classictrucksweb.com/toc/" target="_blank">http://www.classictrucksweb.com/toc/</a> There is an article on doing this same swap that should be of help to you. From memory the stock wheelbase of your truck is 116" if it's a half ton and 125 1/2 if its a 3/4 ton. Track width (mounting surface to mounting surface) is in the 59"-60" range. Good luck, Centerline <a href="http://www.hotrodsandhemis.com" target="_blank">http://www.hotrodsandhemis.com</a> [ April 23, 2003: Message edited by: Centerline ]</p> |
1950 chev truck s-10 swap
hey i am a new member just reading your info on the s-10 swap with your truck i know it is an old post just wondering how you have made out with it?
| Recent General Rodding Tech posts with photos |
