1950 Coronet Front End and Steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2010, 11:45 PM
Dust seals are disintergrated, all of them. I say all of them like it's a big deal because the control arm pivot bars and etc. all still have dust seals and grease fittings. I want to replace it all with modern bushings and so on to eliminate this issue but i don't know where to start. Do i just need to replace the whole front suspension? I know i can just replace the boots for the tie rod ends but i can't find boots for the rest of the suspension.
Old 10-23-2010, 10:03 PM
FLY NAVY
Kanters has a kit for your front end, but before you go that route I think you should google p15-d24.com and you will get the answers you need.
30's to 50's mopars are covered very well there.
Frankie
PS., You have an independent suspension there is no reason to replace it
Old 10-25-2010, 12:05 AM
it's not that i want to replace the front end completly. It's just that all the greased joints and bushings have destroyed dust seals and i can't find replacement dust seals for the suspension. I'll look around P15-D24.com.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Front end wobble and steering wheel shake 85CHEVY Suspension - Brakes - Steering 3 03-10-2009 08:29 AM
Front end 1950 F1 bolt on swap? lelshaddai Suspension - Brakes - Steering 2 05-25-2008 08:19 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 02:29 PM
Steering, P/S and front end linkage??? fireforsin Suspension - Brakes - Steering 1 09-12-2003 02:55 PM
