1950 f0rd coupe. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2005, 02:05 PM
pappyjim's Avatar
Last journal entry: my 50 ford coupe
1950 f0rd coupe.
I got two dashes for the 50 and I'm looking fo anyone who has grafted two together to use the clock and speedo openings thanks....
Old 07-13-2005, 03:05 PM
creativeinteriors's Avatar
Stitching or grease I love it
Last journal entry: Wings and Wheels fly in
Did you post the question before with the microsoft adress in it?
If so I went into detail on how to do it with glass as that is how I am doing it since to me it is simpler that cut and weld.
If you dont want to use that process it is similar by using the two steels only not using the glass molds. You will still have to blend the two steel housings in but they do fit when they are offset but there is alot of forming and slicing needed then strips needed to be added in to get it back in the outside towards the door as the dash drops slightly.
Old 07-13-2005, 04:45 PM
pappyjim's Avatar
so short and sweet will not work fo me therefore i shall ramble about things that matter little to me but since I took 2 hrs to get bacck on I will try to get into this site till my hands drop off. I was building rods back in the 50s so I know I can do this I just wanted soe friends on the sight.
Old 07-13-2005, 06:33 PM
Sorry Pappyjim, I dont know if I upset you or what. I was little confused by your response. I just didnt know if you were the same guy as it is weird to have two posts on the same topic under different names.
Two dashes will work fine, I dont have 2 dashes so for me the glass route was simpler. And thought I should describe an alternative to consider in case you considerd not cutting up two dashes.
You can do it fine with 2 there is just some patch work needed for the shift on the driver door side as the dash has a downward tapper and the passenger shifts fine. In all you just need to fill and some feathering. If you have been hot rodding since the 50's it could be a snap for you.
Hope you find what your looking for and welcome to the site.
Old 07-14-2005, 08:00 PM
joeford's Avatar
36 Dream
Speaking Of Dashes....have You Ever
I've seen a 40 Ford Dash used a couple of times in 35-37 Fords...Can someone tell me if this is a difficult installation? For instance is the contour and width the same as the mid 30's?
1950 Chevy deluxe business coupe floor shifter A/G WILLYS Transmission - Rearend 4 12-31-2012 09:33 PM
Differences in a 1937 chevrolet coupe montecarloman General Rodding Tech 5 11-10-2010 10:12 PM
Chassis building for my '35 Pluymouth coupe 35plymouthcoupe General Rodding Tech 9 08-15-2005 09:34 AM
building a 1950 plym. bus. coupe. bdv Hotrodders' Lounge 5 01-25-2003 03:54 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
