1950 Ford 3.0 V6? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2006, 07:45 PM
CrashFarmer2's Avatar
Freezing in arctic Iowa
Last wiki edit: Pre-1980 VIN decoding
Last journal entry: 1978 Chevy pickup battery tray repair
Wiki Edits: 409
1950 Ford 3.0 V6?
I have a 1950 Ford with a flathead V8 and a three-speed overdrive transmission. When I originally purchased the car I had planned on putting in a more modern V8 and it has not moved out of the planning stage.
But lately considering the high price of gas I have been thinking about going a different direction with it. I have a 1989 Ford Aerostar van with a 3.0 V6 and a 5-speed transmission, the body is trashed on this van but the engine runs great.
I have been thinking about putting the 3.0 and the 5-speed in the 50. I think it should have adequate power since the 3.0 is rated at around 145 horsepower and the original V8 was rated at around 100 horses.
I am thinking that the end result should be a nice driver that is fairly easy on gas, what do you think?
Old 03-03-2006, 10:57 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
It's a great idea! The 3.0L probably puts out more torque than the original flat head V-8 too. A lot of people on here will say "go with a V-8", but if you're buidign it to drive and want to enjoy driving it, put the V-6 in. It won't quite be a hot rod, but it will be much better than the original V-8. HP really doesn't mean all that much, the torque does. The 50 weighs less than the Aerostar, so it should perform better than it did. I'd use the Aerostar rear end also, or gear the 50 rear close to the same. Within 0.5 of the ratio (+ or -) should be fine.
I built my last car as a driver and went with a hopped up six vs. a V-8 and I don't regret it one bit! I stroked the six from 244 to 282 inches, and sometimes wish I hadn't though! Gave up a couple mpg, but not enough performance added to notice without a stop watch. I don't regret doing it, but if I were going to build another I'd leave the engine stock except for exhaust and maybe a cam change (I have a mild cam also). The stroking is done a lot by Jeepers (it's the Jeep 4.0L, stroked to 4.6L) because it gives a big boost in low speed torque. There's a HP gain also, but it's higher in the rpm range than you normally use. The extra low speed torque isn't really needed in a street car, the stock 4.0L engine has plenty.
Old 03-03-2006, 11:50 AM
Wiki Edits: 409
That is good to hear, I have been wondering lately if I am not getting old crazy and needed slapped silly. Not that I wasn't a little crazy to start with. Going from a V8 to a V6 would have sounded like insanity to me twenty years ago but gas was cheap and I wanted to go fast. I have went from a 6 to to a V8 so now might be the time to try this new thing.
I checked out your gallery pictures and that wagon looks good. What kind of mileage are you getting with the Jeep engine? My Cherokee has the 4.0 and is getting from 15 to 19 mpg (it gets around 19 if I drive it and 15-16 if my wife or kid drive it).
Old 03-05-2006, 08:42 AM
Crash, My Bud and I replace the flathead in his 51 Business coupe with a 302 with 2 barrel. An old style Bronco oil pan was required to clear the cross member (still had to modify the cross member slightly to get the motor as low as we wanted) and we used a late model 3 speed with overdrive tranny. We kept the original rear end. He now gets almost 20 MPG on the open road and 17 daily driving. He can't help putting his foot in it since it is a fun car to drive. Big increase in performance as well as fuel economy. Even though the Astro Van and shoe box is probably close to equal in weight, the smaller 3 Liter may be laboring a bit vice the 302 (5 Liter). Regardless of which way you go, make sure you have EFI and you will increase fuel mileage and performance over the carbed units. I vote for the 5.0 from an early 90s Mark VII or Towncar, or Mercury. They are common as dirt and you can find the Air Bagged cars with low mileage cheap. But you already know that.
Trees
Old 03-06-2006, 08:38 AM
farna's Avatar
Wiki Edits: 14
Crash, I average 18-19 mpg, get 20-22 on the road depending on how I'm driving. I got closer to 24 mpg with the stock 4.0L, and could barely tell a difference in performance.
Don't think the 50s cars are as heavy as later ones because they are near the same bulkiness (apparent size)!! The 50s cars didn't have as many layers of metal nor things like 20# crash bars in the doors. The shoebox weighed around 2700 pounds (http://www.uship.com/listing.aspx?packageID=35809), the Aerostar closer to 4000 (http://cgi.liquidation.com/auction/view?id=795205). These weights aren't exact, but there is still around an 800-1200 pound difference in the 50's favor! Even if you use the smaller number, that's enough to make a noticeable performance difference.
Old 03-11-2006, 09:58 AM
Wiki Edits: 409
The original flathead was rated at 100 horsepower but it had 180 ft-lbs of torque. The 3.0 was rated at 145 hp and 165 ft-lbs of torque. I wonder how much difference would be noticed while driving?
On the other hand, I do have a rear-sump 302 out of a wrecked 1989 Econoline and I have a 4-speed overdrive transmission out of another Econoline.and I still have the 89 van so I could pull the wiring and computer out of it. The V8 would sound better.
Old 03-12-2006, 06:32 AM
Thats where I would spend my enegry. The 302 with overdrive will be loafing with several extra ponies if you want them. Also, the mild engine will let your original rear end live a long life. Couple this with EFI and you will have your economy car!!!
When you get the car on the road, why don't you run it across the scales to see what it weighs. I think it will push 3000+#s.
Trees
Old 03-13-2006, 09:06 AM
farna's Avatar
Wiki Edits: 14
Crash, I posted about this in another thread somewhere! The flat head is rated at gross HP and TQ -- the 3.0L rated at net HP and TQ. Subtract 30% from the flat head ratings to get a near equivalent to the 3.0L. That makes the flat head 70 hp and 126 ft/lb. The rating method changed after 1971. Anything built 71 and earlier is rated with the gross method, 72 and later net. Usingthe raw numbers is like comparing apples and oranges. The 3.0L is a good bit more powerful. Some people just won't give up on a V-8 just for the sake of having one! The only drawback to the 3.0L is that you have to use the EFI computer system. I don't see it as areal drawback, not if you havethe entire donor vehicle. It's not that hard to wire it in.
Old 03-18-2006, 03:05 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
If you drive it 10,000 miles a year, how many dollars will you save on gas compared to a 5.0 fuelie?
Will you be satisfied with what you have to drive?
Old 03-21-2006, 06:45 PM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
Crash, you've got a private message. (My son lives in Greenfield.)
Ford Flathead to Ford automatic c4-kit? bigjim Engine 4 01-05-2005 02:11 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
Henry Ford in Heaven schnitz Hotrodders' Lounge 9 10-19-2004 10:09 AM
ford v6 torque Bob Ruth Engine 9 06-26-2003 12:05 AM
1950 Ford Anitfreeze leak ebiosca Engine 0 04-06-2003 04:05 PM
