1950 ford flathead-overheating - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2012, 08:19 PM
Rebuilt flathead, thermostats removed, new aftermarket 4 row HD radiator,
Mallory Electronic Distributor, 7 lb pressure cap with overflow bottle.
still overheats- any suggestions?
Old 06-11-2012, 08:56 PM
justold's Avatar
put the t-stats back with out them they will flow a lot of water . and check the timing , those old flatties will handle quite a bit .
Old 06-11-2012, 09:29 PM
justold is dead on about the timing. Nothing will make a flathead heat up quicker than the timing being retarded. Also be sure all your radiator baffles are in place. Do not let the hot air recirculate around the radiator. Henry was too cheap to put them there if they weren't necessary. Good luck.
overheating flathead convert Engine 10 10-18-2013 04:59 PM
1950 mercury Flathead Engines rsfyj Hotrodding Basics 21 03-03-2012 10:27 PM
1950 Ford Flathead-8 question Erik Transmission - Rearend 7 03-27-2009 09:19 AM
flathead V8 for a 1950 Lincoln Cosmo helenwheels Engine 20 08-20-2008 03:23 PM
1950 Flathead wildtaxi21 Engine 2 04-04-2006 02:38 PM
