1950 Ford V8.. No Spark? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2012, 08:47 AM
Dave E Shank's Avatar
We have a 1950 Ford with a flathead V8 that will not spark? We have replaced coil, points, condenser but still no spark?? Any suggestions? THANKS Dave Shank
Old 05-09-2012, 08:53 AM
Verify voltage at both sides of coil and at points when points are open. That will tell you where your open circuit is. If you have no voltage at either side of the coil you will know you have a blown fuse, bad switch, loose connection etc in the ignition circuit.
John L.
Old 05-10-2012, 10:43 AM
We found the problem: The ground wire that connects to points was not connected, it had dropped down below the breaker plate. Car running like a song.... THANKS... Dave Shank
Old 05-10-2012, 10:50 AM
Post a picture when you can. Glad it worked out.
J L
Old 05-10-2012, 03:20 PM
Last journal entry: My Last Hot Rod
Remember
flat head Fords are Positive ground unless it has been changed....
1950 ford with no spark. chaosad74 Engine 3 06-20-2010 12:06 AM
Ford f-1 - 1950 qdeck@msn.com General Rodding Tech 3 08-25-2009 11:09 AM
1950 Ford michelle felice Introduce Yourself 2 04-17-2006 12:02 AM
1950 Ford 3.0 V6? CrashFarmer2 Hotrodding Basics 9 03-21-2006 06:45 PM
1950 ford f6 johnauto Suspension - Brakes - Steering 0 11-20-2003 06:27 PM
