1950 panel lots of rust - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2012, 04:24 PM
OK I'm taking it to metal then rust treatment and a coat of primer. Does any one have a suggestion on what is a good treatment for preventing rust. What is the best primer filler paint
Old 07-09-2012, 06:07 AM
deadbodyman's Avatar
Wiki Edits: 11
Man these rust threads never die...Weve discussed rust and how to remove it many ,many times...How about a few pics...Until then use the search button and use rust or Ospho for the key words.basicly stay away from the encapsulators,the only good way is to REMOVE the rust by using acid or media blasting or cutting it out and replacing with new metal... epoxy primer is best over bare metal...there are preferd brands of epoxies but you'll need to do a search on epoxy primers and do a little reading to get a fair and balanced opinion of what brand to use...
Be forewarned these two topics have enough info to keep you reading for a week...or two
1950 Willy's wagon/panel truck chassis? ALS927 Hotrodding Basics 3 11-03-2006 03:28 PM
New..have question about panel rust repair zimaad Body - Exterior 3 12-13-2005 10:40 PM
Cutting out sail panel rust.... PairOf69's Body - Exterior 2 12-04-2005 07:18 PM
Cutting out sail panel rust.... PairOf69's Body - Exterior 1 12-04-2005 06:17 PM
Panel alignment ?'s 1950 Chev convertible baddbob Body - Exterior 4 08-07-2005 07:53 AM
