1950 Plymouth coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2012, 11:18 AM
Rulah's Avatar
1950 Plymouth coupe
How to make home made interior panels for a 1950 Plymouth coupe
Old 03-10-2012, 11:40 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Here you go: CLICK HERE This shows a custom door panel, not a copy of the original, but the principles are the same.
Old 03-11-2012, 12:31 AM
JeffB's Avatar
If you are doing a budget build this article should help:http://www.cadvision.com/blanchas/54...oorpanels.html I did this with my '54 Ford and it set me back a total of $125 for all four panels.
Old 03-11-2012, 08:42 AM
Wiki Edits: 22
Except Masonite is about the worst thing you can use for door panels because it is intended for indoor use. Masonite, even the oil impregnated type which is far more expensive, does not hold up to moisture. When exposed to moisture, Masonite will become rubbery and fail. Masonite is also brittle, especially at 1/8" thickness. If you try to take your door panels off for any reason, you can break the panel board and end up doing it over. There are many far better things to use for door panel boards. The two best products are PVC foamboard and waterproof panel board. Neither one of these is any more expensive than Masonite.
Also, the aerosol glue that was used may hold up for a while, but I guarantee it will fail as soon as the car sits out in the sun a couple times. If you are gluing anything in a car interior, you need to use high heat resistant top and trim adhesive, which actually gets stronger as time goes by. A gallon of quality top and trim adhesive Like DAP costs about $30, and together with a $20 siphon feed spray gun, costs less than the $52 spent on spray cans and will do 3 or four sets of door panels, or more.
Old 03-12-2012, 07:49 PM
Rulah's Avatar
Thanks for your help
To DantwoLakes,JeffB,
Thanks for all the help guys. I'm new at this restoration stuff, I bought a 1950 Plymouth 3 window coupe. It needs floor panels the vehicle runs n also leaks oil when it's parked. Have a good day
1950 plymouth businessmans coupe frame swap candidates..... Nubsauce General Rodding Tech 20 08-27-2011 07:16 PM
My 50's plymouth fleet ;] 1949&1950 SocialOutkast49 Introduce Yourself 1 02-14-2009 07:21 AM
1950 plymouth convertible jackndelphine Hotrodding Basics 6 01-08-2007 06:09 PM
1950 Plymouth convertible 302 EFI Swap jackndelphine Introduce Yourself 3 01-08-2007 06:28 AM
chop 1950 plymouth deluxe randy k Introduce Yourself 2 01-01-2006 07:15 PM
