Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1950 truck frame swap to 1980's chevy frame
Old 07-18-2011, 04:25 PM
matt167 matt167 is offline
Wiki Edits: 31
4x4 can be added to the factory AD frame, if this is your reason, for the swap, just find an axle from somthing that kinda matches the track width, like a Cherokee or somthing. If you want IFS, then you could use somthing like a nova clip
