Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1950 truck frame swap to 1980's chevy frame
  #25 (permalink)
Old 01-24-2013, 06:05 PM
coolhhr coolhhr is offline
frot sus
put a camero front suspsion on it. It all unbolts from the car. I will monut right up under your from. Only need a 1/4 spacer on each side , the bolt it all on very simple. Also use the steering box mount it on the out die of the frame & you are on the way. You the stil use all factory parts No welding or hacking the frame.
