1950 truck frame swap to 1980's chevy frame
Does anyone know what mid 1980's frame will work for 1950 chevy truck swap?
None.
Before we go anywhere with this, why are you expectations? A frame "swap" is not simply unbolting and bolting in the new, it takes a LOT of modifications. If you think you are saving money over putting in a front end from the hot rod shops and a different rear end you are kidding yourself. If you have never driven one of these trucks with a proper suspension you don't know if it will meet your expectations. They drive darn nice when things are rebuilt and working properly. Brian |
4x4 can be added to the factory AD frame, if this is your reason, for the swap, just find an axle from somthing that kinda matches the track width, like a Cherokee or somthing. If you want IFS, then you could use somthing like a nova clip
Take a look at this site. It's for a Ford but will give you an idea what's involved.
frame swap question
Thanks everybody for you insights, I keep looking.
1950Truck |
Before I would put another truck frame under it. I would buy a updated front end or put a Nova clip under it... As for the ride,, I had one with a camaro clip... You won't beat it.... A very big difference....But there is so many different ways you can go.... I would never go from one truck to another truck frame... Sorry,, That's just me..
frame swap question
Thanks for your insight I starting to believe that that is the way to go. I just need to find a car or truck with the right track width. I know the 80's corvette suspensions work very well BUT! they are so expensive. Maybe I can find another vehicle with the same track width simular to the corvette's
that wont be so expensive. Thanks again for your help. |
no fabrication or modification required. it's as easy as changing starters. but; before you do it... do a simple ''frame swap'' search on this forum. :evil: :evil: :evil: :evil: :evil: :evil: |
I also have done the frame swap routine. I put a 36 Chev p/u cab on a mid 70's Chevrolet 1 ton extended cab frame. The owner then had a hydraulic dump flatbed deck built. The cab fit with minimal modifcation to sheetmetal and just had to build body mounts and radiator support. It turned out excellent. I then installed off the shelf lowering parts to get the stance. It had a 454, Turbo 400 and A/C too! Andy |
suspension for my 1950 chevy pu A-frame
Thanks Andy!
The corvette subs is the way I want to go but only one problem MONEY, but I think I'm just going to save up and buy them at one time including the assembly kits thats on the market. But if would be nice if I could find some suspensions that would work as good but less cost. Thanks for your help! Taylor |
You could go Corvette front suspension and live axle rear, that could save you some money and you can still get great results.
Andy |
Hadn't thought about that but that would save me a lot of money. Thank you for your help.
Taylor |
Didn't know that either, so hopefully I can find some other type of suspensions that might work or I may have to buy a few parts at a time from one of these after market companies that sell front and rear IFS and IRS, for that's what I want to do. So looks like I'm going to have to wait a while before finishing the chassis and suspension.
Thanks for you help! Taylor |
| All times are GMT -6. The time now is 03:26 PM. |
