1950 truck frame swap to 1980's chevy frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2011, 02:40 PM
Does anyone know what mid 1980's frame will work for 1950 chevy truck swap?
Old 07-18-2011, 03:54 PM
None.
Before we go anywhere with this, why are you expectations? A frame "swap" is not simply unbolting and bolting in the new, it takes a LOT of modifications. If you think you are saving money over putting in a front end from the hot rod shops and a different rear end you are kidding yourself.
If you have never driven one of these trucks with a proper suspension you don't know if it will meet your expectations. They drive darn nice when things are rebuilt and working properly.
Old 07-18-2011, 04:25 PM
Wiki Edits: 31
4x4 can be added to the factory AD frame, if this is your reason, for the swap, just find an axle from somthing that kinda matches the track width, like a Cherokee or somthing. If you want IFS, then you could use somthing like a nova clip
Old 07-18-2011, 05:41 PM
Take a look at this site. It's for a Ford but will give you an idea what's involved.
Old 07-18-2011, 06:12 PM
frame swap question
Thanks everybody for you insights, I keep looking.
1950Truck
Old 07-19-2011, 12:52 PM
A frame swap is a lot of work and fabrication, even on something as simple as an AD Chevy truck. The S-10 swap is the most common. I suggest you use Google to learn more. There are a lot of sites out there that describe this swap.
Old 07-19-2011, 04:42 PM
life is a temporary assignment
Before I would put another truck frame under it. I would buy a updated front end or put a Nova clip under it... As for the ride,, I had one with a camaro clip... You won't beat it.... A very big difference....But there is so many different ways you can go.... I would never go from one truck to another truck frame... Sorry,, That's just me..
Old 07-19-2011, 06:17 PM
frame swap question
Thanks for your insight I starting to believe that that is the way to go. I just need to find a car or truck with the right track width. I know the 80's corvette suspensions work very well BUT! they are so expensive. Maybe I can find another vehicle with the same track width simular to the corvette's
that wont be so expensive.
Thanks again for your help.
Old 07-19-2011, 06:28 PM
ogre's Avatar
the 'Duracell Project'
it's easy, any 80s gm frame will bolt under your 50 chevy truck.
no fabrication or modification required.
it's as easy as changing starters.
but; before you do it...
do a simple ''frame swap'' search on this forum.
Old 07-20-2011, 06:04 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
You are talking about the 84-96 Corvette C4 suspension I would guess. For what you get with them, there is no better bang for the buck. I buy them for around $600.00-$700.00 per end and you get 4 wheel disc brakes, posi, rack and pinion steering, aluminum a-arms and other suspension parts and composite springs. I have done many conversions to this suspension and it always works out great if you have a wide enough vehicle such as yours. The conversion is easier on trucks also, especially the rear end.
I also have done the frame swap routine. I put a 36 Chev p/u cab on a mid 70's Chevrolet 1 ton extended cab frame. The owner then had a hydraulic dump flatbed deck built. The cab fit with minimal modifcation to sheetmetal and just had to build body mounts and radiator support. It turned out excellent. I then installed off the shelf lowering parts to get the stance. It had a 454, Turbo 400 and A/C too!
Andy
Old 07-20-2011, 10:06 PM
suspension for my 1950 chevy pu A-frame
Thanks Andy!
The corvette subs is the way I want to go but only one problem MONEY, but I think I'm just going to save up and buy them at one time including the assembly kits thats on the market. But if would be nice if I could find some suspensions that would work as good but less cost.
Thanks for your help!
Taylor
Old 07-20-2011, 10:28 PM
aosborn's Avatar
Wiki Edits: 7
You could go Corvette front suspension and live axle rear, that could save you some money and you can still get great results.
Andy
Old 07-21-2011, 09:30 AM
Hadn't thought about that but that would save me a lot of money. Thank you for your help.
Taylor
Old 07-21-2011, 09:51 AM
Taylor
Just keep in mind... When you will need to replace any part's... They are twice as much..
Old 07-21-2011, 10:56 AM
Didn't know that either, so hopefully I can find some other type of suspensions that might work or I may have to buy a few parts at a time from one of these after market companies that sell front and rear IFS and IRS, for that's what I want to do. So looks like I'm going to have to wait a while before finishing the chassis and suspension.
Thanks for you help!
Taylor
frame swap for 1950 chevy truck truck1950 Hotrodding Basics 39 06-24-2015 02:40 PM
1950 chevy swap to s-10 frame jason fitzloff Hotrodding Basics 6 03-10-2012 07:06 AM
frame swap for 1950 chevy p/u chevykid33 Introduce Yourself 2 08-13-2007 10:05 PM
1950 chevy frame swap trott Hotrodders' Lounge 2 12-23-2002 09:26 AM
