1951 Chevy business coupe, replaced the 3 speed with a 4 speed transmission. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2011, 08:24 PM
I put a Saginaw 4 speed in my 1951 Chevy Business coupe and it won't shift. I've adjusted the clutch and while the engine is off it will go into the forward gears but not reverse. When I start the engine it won't go into any of the gears.
Old 08-08-2011, 08:35 PM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Engine running, not going into gear, off the top of my head sounds like the clutch is dragging, readjust. Cannot find reverse shifter not set up correctly verify that. More information will get you more accurate troubleshooting suggestions. What is the brand name of shifter ?
1937 chevy coupe vs business coupe a70dart General Rodding Tech 12 11-08-2012 01:05 PM
1951 chevy coupe high voltage Body - Exterior 1 12-09-2008 09:35 AM
58 Chevy Delray business coupe Quick 58 Introduce Yourself 1 10-19-2007 12:15 PM
stock wiring 1951 plymouth business coupe jdockham Electrical 0 05-21-2004 10:35 AM
5 or 6 speed into a '33 Ford Coupe Stubby Transmission - Rearend 3 09-19-2002 10:03 AM
