1951 chevy coupe Rear ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2006, 11:12 PM
1951 Chevy coupe Rear
hi guys
I have a 1951 2dr Chevy coupe and it has its original rear in it and I知 looking to update it . I知 putting in a b&m 400 turbo trans and I won稚 something strong and dependable. I知 looking for something in the late 70's or newer. what kind of car would you guys say i could get this rear out of.
thank you
Dan
Old 04-14-2006, 10:27 AM
Wiki Edits: 31
2nd gen Camero rear end's swap right in i'v heard. find 1 in a yard, measure to be shure it will fit.
you couldn't use the original rear with a T400 anyway, it's a torque tube rear, and likely 4.11 gears at that. Luckily being my car is a PG car, I have 3.55 gears
Why run a T400? BB's don't fit in a early 50's Chevy without a lot of work, and the T400 will take a lot of power from a SB, T350 is a better choice. also, you will need to relocate the e brake stuff, it's in the way for a V8.
Old 06-09-2006, 09:17 PM
1951 chevy Rear ?
hi I have a 1951 chevy Styleline Delux sport Coupe
and i want to update the rear I was wondeing if any one would know the mesurements and out of what car i would get the rear out of ?
thank you
Dan
Old 06-11-2006, 11:07 AM
hi guys
as you all might know that im building a 1951 chevy skiline Deluxe sports coupe and im looking to update the rear i think im going to go with a nova rear.
but my ? is what gear rasheo should i go with? i know i want a posi rear and something good on gas to but a stong and dependable one to.
if you can get back to me asap it would be helpfull.
thank you
Dan
Old 06-11-2006, 11:51 AM
RDavid's Avatar
51 Rear End
I have a 50 Chevy Fleetline.. The first thing to consider for me was the width which I measured to be 60" outside to outside. I ended up using a 73 Camaro Posi I picked up on Ebay. It is a 350 ratio.. I liked that because I want to cruise mostly but get there sort of quick. I also have a 700R4 Tranny so that helps with gas etc.
Just a note.. I have a couple of friends who used 55-57 chevy rear ends with great success... Another that fits is a late model S-10 so you can have disc brakes if you can afford it ....
Get what fits under there. Just keep in mind that you will only be able to use 8-9in tires because of the way the inner fenderwells are made.
I am tubbing a little to fit larger tires under there. Instead of using a cut down rear, I am doing backspacing on my wheels for the larger tires. 10-12 Inches. I narrowed my chassis using a driveshaft loop crossmember and some braces. It really strenghtened up the chassis. If want to see just email me.
RD
Old 06-11-2006, 09:38 PM
The rear end under your car originally was in the 59 inch range. Measured this way ...
I have used 57 to 59 Ford passenger car rear ends under the 49 to 54 Chevrolet cars ... but then ... I use them under almost everything I do ... 78 up Monte Carlo and Malibu rears also work nice ... and have the standard GM Chevrolet wheel pattern ( 5 on 4.5 ) .
Here is a link that lists a good many vehicle widths ... both front and rear ... for common American vehicles .
http://www.quickperformance.com/Tech...us_measure.htm
Old 06-12-2006, 09:38 PM
51 chevy rear ?
you said something about a S-10 Rear. my friend said thats a good rear to use but he didnt know out of what year S-10 to take it out of .all he said is make shur its 2wD and it has a 309 or a 310 Gear Ratio.
also would you know if they came with a posi rear with a 309 or 310 gear ratio ?
thenk you
Dan
Old 06-12-2006, 09:42 PM
51 chevy rearend update ?
hi guys
i have a 1951 chevy coupe my stock rear i mesured from backing plate to backing plate at 54 in and i would like to update my rear .
so.
my friend said thats a S-10 rear is good rear to use but he didnt know out of what year S-10 to take it out of .all he said is make shur its 2wD and it has a 309 or a 310 Gear Ratio.
thenk you
Dan
Old 06-12-2006, 09:56 PM
RDavid's Avatar
Now keep in mind that I dont know all that I understand about this but.......From all I have heard you do want one out of a 4wd because a lot of them are limited slip and the 96 and above have disc brakes...
Just a thought....
Old 06-12-2006, 10:23 PM
Do you NOT read the replies to your questions ... or do you just sit around and ask questions trying to raise your post count ... ??
And then ...
http://www.hotrodders.com/forum/1951...ear-91375.html
Most of your questions have been answered ...
Not trying to be HARD about it but ... your credibility is sinking fast ...
Old 06-12-2006, 11:39 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Area_51....
folks here are trying to help you.
I merged a few of your posts where you ask the same basic questions.
Please do not start a new thread with the same questions again...
I will dump all new threads with the repeated rear diff question
thx, have a nice day.
Old 06-13-2006, 10:20 PM
hey guys
hey guys
just wounted to say sorry for posting the same thing 2ce it was just a long day and a late night and i probally didnt even think about it i just wounted to find out since this is my 1st time doing this i just want to make shure im using the right parts sorry agen.
thenks agen
Dan
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
i got ford parts on my chevy rear axle roy383ci Hotrodders' Lounge 0 09-11-2005 04:31 PM
56' Chevy Rear Bumper Question maxie56 Body - Exterior 2 05-25-2005 10:11 AM
48 Chevy Truck rear fenders bg Body - Exterior 2 10-31-2003 07:30 AM
Rear end swap for '53 Chevy truck Bruce H Transmission - Rearend 4 12-01-2002 12:43 PM
