Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1951 Chevy steering box
Old 03-28-2012, 02:06 PM
matt167 matt167 is online now
Wiki Edits: 31
The worm gear shouldn't be that bad that it really needs replaced, unless it's catching and you can feel it, which would indicate damaged teeth... Do the over center adjustment and other adjustments as indicated in the 1949-1952 shop manual ( it's online in the old car manual project. just google it ). It should fix it right up..
