1951 chevy styleline deluxe booster - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2009, 03:40 PM
Hello!
I bought this 51 chevy about august last year, and when i got it the engine wasnt running and the master cylinder was not working. Well got the engine running, but i want to upgrade the the brakes to power brakes. I got the booster kit for it but i cant figure it out.
What can i do to install it?
Thanks!!!
Old 02-16-2009, 04:09 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Didn't the kit come with instructions? does it look like the
kit in the picture in the link? what is it you don't understand?
Rich
Old 02-16-2009, 11:18 PM
brake booster
No, the part didnt come with instructions.
I bought the part on ebay. The bracket bolts on right but i cant put the booster on because it will hit the park brake, and the pedal doesnt aline.
Do i need to modify it do fit or should it fit right in.
Old 02-17-2009, 10:40 AM
Hi,
Some of those kits won't work on convertibles, will only work on original "k" frame, works only with automatic transmission, some were for trucks they look similar but I think they are longer causing interference with the parking brake pulley, you don't have many choices, either try & get the installation instructions, or try & get your money back, then get a good kit, or modify what you have to fit your car.
Rich
http://www.chevytalk.org/fusionbb/sh...hp?tid/208650/
http://www.americanclassic.com/Googl...R2917-1951.htm
1950 Chevy deluxe business coupe floor shifter A/G WILLYS Transmission - Rearend 4 12-31-2012 08:33 PM
66 Chevy brake booster help? badriand Suspension - Brakes - Steering 1 06-03-2007 02:01 PM
1952 chevy 2 dr bel air deluxe project kipper Introduce Yourself 2 09-13-2006 10:11 AM
1951 chevy automatic, conversion to stick lgsteelhead Transmission - Rearend 2 01-29-2003 05:51 PM
Drop spindles for 1951 chevy lgsteelhead Suspension - Brakes - Steering 2 01-02-2003 06:58 AM
