1951 Chevy truck rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2012, 09:52 PM
Hi , I'm new to this site . I have a 1951 Chevy 3100 pickup (all stock running gear......closed torque tube),.I'm interested if anyone knows which modern Chevy 6 bolt rearend would work on this truck to drive it on the highway . Thanks for the help !!!! Bruce
Old 02-18-2012, 09:58 PM
Crosley's Avatar
Wiki Edits: 1659
You have to convert to open drive shaft. I used a 1969 Chevy truck differential with the 6 lug wheel axles in my 1950 Chevy truck.
the springs need changed too Or build new plates to locate the axle center line correctly in the fender opening. The leaf springs bolt on closed drive line (torque tube) locate the axle differently.
Old 02-19-2012, 11:20 AM
Crosley,Thanks for the help ,now I can do MORE research, Bruce
Old 02-19-2012, 04:29 PM
Wiki Edits: 31
there is a vendor that makes 3.35 gears for the original rear, so you can go over 50 MPH with stock running gear
Old 02-19-2012, 08:51 PM
ogre's Avatar
the 'Duracell Project'
http://www.chevytrucks.org/tech/ifs&rearend.htm
scroll way down
1951 Chevy Truck 3/4 Ton shop truck csparkhurst Introduce Yourself 2 01-18-2012 11:54 AM
1951 chevy panel truck lblsk Introduce Yourself 7 09-19-2011 05:45 PM
1951 Chevy truck fillerup42 Suspension - Brakes - Steering 0 06-28-2010 10:09 PM
1951 Chevy Truck chevblazk5 Suspension - Brakes - Steering 3 01-26-2006 08:27 PM
Interior for 1951 chevy truck Turkey Interior 2 03-12-2002 09:44 AM
