1951 ford pickup question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2007, 07:31 AM
Hi All!
I am new to this site!
I have a 51 ford pickup and am looking for the easiest/ best way to update the chassis. Any ideas would be appreciated!
Thanks Phil
Old 10-26-2007, 07:33 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
try this swap
Old 09-09-2008, 07:53 PM
can i put my 51 f1 body on a 72 f100 frame
Old 09-09-2008, 08:01 PM
poncho62's Avatar
Wiki Edits: 5
I put a 76 Nova clip in my 51............worked out well.
ID:	32392   Click image for larger version
ID:	32393   Click image for larger version
ID:	32394   Click image for larger version
ID:	32395   Click image for larger version
Ontario Rodders
Old 09-09-2008, 08:03 PM
poncho62's Avatar
Wiki Edits: 5
It would be too wide, I am sure.
Ontario Rodders
Old 09-09-2008, 08:07 PM
thats what i was thinking that it would be to wide as far as subframe i donno how to do that i was just wondering if it would work....nice truck by the way
Old 09-09-2008, 09:50 PM
I have a 51 F1 with a speedway MII econo crossmember and factory MII suspension with a 9" with the spring hanger flip trick. It sits nice and low and should ride good. I spent about 600.00 putting the crossmember in including all of the rebiuld parts and rotors.
I know everyone says the MII stock stuff is junk but my Chevy II had it under it and it ran over 150 MHP and 9.0s in the 1/4 with no problems for the 10 years I owned it.
You can go to webshots and do a search for MPH racing (one word) and it should come up.
Old 09-11-2008, 11:44 PM
what is the spring flip trick? sorry im new to this
Old 09-12-2008, 02:01 PM
Take your rear spring perches off and flip them over. You have to drill the rivet holes out a little to get a 3/8 bolt in then bolt them back on. I took 5 of my 10 leaves out of my springs and took them to a spring shop to have the main springs arch reversed (the eyes are wound upside down for the hanger flip) it had to sit at least 5-6" lower than stock. I still have the rearend under the spring, if you did an axle flip you would have to C notch the frame for clearance but I think it would be too low at that point.
Here is a link to some pictures of my truck all of the ones after the suspension are with no engine or trans in it.
http://good-times.webshots.com/album...TnqcgV?start=0
Old 09-12-2008, 09:34 PM
do u or any one elce have pic's of the springs when done?
Old 09-13-2008, 08:47 PM
I will take a few and post them. We just went through hurricane Ike so it may be a few days.
Old 09-13-2008, 11:41 PM
ok thanx...srry to hear that
Old 02-16-2009, 12:19 AM
hey i was wondering if i could get some pic's of the spring hanger flip
Old 02-16-2009, 07:45 PM
I have it back in the shop working on it so I will get it jacked up tomorrow evening and take a few pictures and post them to this thread.
Old 02-16-2009, 08:04 PM
ok thanks i havent had time to work on mine till now so im looking in to it agine
Big Block Chev. into 61 ford pickup Gene Beyer Introduce Yourself 2 11-26-2007 07:38 PM
1951 ford pickup ? phil wellman Introduce Yourself 2 10-25-2007 01:03 PM
350 sbc in a 1951 ford 51FordDuff Engine 9 07-18-2005 11:10 AM
32 ford pickup captainflyte Introduce Yourself 1 10-29-2004 10:06 AM
1932 Ford Pickup and 1933-34 Pickup Different? YES pasadenahotrod Transmission - Rearend 1 10-23-2002 02:20 PM
