1951 ford truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2006, 10:12 AM
1951 ford truck
i need to know how wide a stock rear fender is for a 1951 ford f1 truck. i am building one but dont have any fenders to know how much to cut down a 9 inch axle. (shorten) thanks for any help . scott
Old 11-22-2006, 10:42 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
I don't know how wide your fenders are but here is some info that may tell you how wide to make your rear end:
http://www.ford-trucks.com/article/i...ial_Swaps.html
Old 11-22-2006, 08:47 PM
all I can say is that the rear end I put in my 50 f1 is 61.25 from the wheel mount to wheel mount I can go and measure my 50 if you like. ED I get 12.5 in inside the fender to the bed of the truck at about 3 in above the tire. I believe it was from a 9" 73 Mustang.
Old 11-22-2006, 09:32 PM
poncho62's Avatar
Wiki Edits: 5
On my 51, I had more problems with interferance against the box than the outer fenders. I would mearure the fenders for you, but the truck is in storage ar my daughters house for the winter. Next time I am there, I will try to remember to measure it.
Ontario Rodders
66 ford truck twin i beam lowering tech igotachevyor2 Suspension - Brakes - Steering 15 12-16-2011 07:45 AM
1951 Chevy Truck chevblazk5 Suspension - Brakes - Steering 3 01-26-2006 08:27 PM
1951 ford truck brutus_donkey Transmission - Rearend 3 01-10-2006 12:34 PM
51 Ford Panel Truck BAD TO THE BONE 413 Introduce Yourself 4 01-02-2006 06:38 PM
1951 ford f1 truck brutus_donkey Suspension - Brakes - Steering 4 11-08-2005 07:33 AM
