#1
1951 Jeepster column?
I'm building a 1951 Jeepster. So far I've installed a Fat Mans Mustang II suspension and a 1994 4.3 Chevy V6 with a 1986 2004R Trans. I want to install a tilt column with a column shift. It looks like 32-35 " long might work. Has anyone done one of these? also I don't want to deal with an air bag column and would like to have the column shift indicator be compatable with the 2004R shift pattern. Any thought would be appreciated. Thanks, Tom
Register now (free) or login to remove ads |
#2
2004r came in some 82-86 caddy's
all will have tilt.. I say look there first as the j/y will more than likely give you the column.. the g body used the 2004r but ,bacause they are still high theft.. most junkyards want more for them not 100% but a s-10 with a 7004r will have the same gear indcator 1/2/d/ov same with full sized.. and you are fabing up the linkage to the 200r4.. they should work.. |
| Thread Tools | Search this Thread |
| Similar Threads for: "1951 Jeepster column?" | ||||
| New guy with Jeepster project | T Evans | Introduce Yourself | 3 | 12-27-2011 11:49 AM |
| Jeepster 1945-new member | jeepster1945 | Introduce Yourself | 2 | 01-13-2011 02:59 PM |
| jeepster | 31chevy | Hotrodding Basics | 1 | 08-02-2008 11:43 PM |
| column drop for a 2.5" diameter column | bet on black | Suspension - Brakes - Steering | 3 | 04-05-2007 12:03 PM |
| power steering on 50 jeepster | retired 56 | Suspension - Brakes - Steering | 2 | 03-01-2007 05:22 AM |
