1951 Mercury Do you go 350 or 351? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2005, 06:31 PM
Please Help me! I have a 1951 mercury and I am trying to decide weather to go with a 350 tpi or with a 351. I know that I would have to put some mounts in for the 350 but What i would like to know which one would be better for the rod. Thanks for your help. Robert
Old 04-13-2005, 07:33 PM
Wiki Edits: 49
I'm a Mopar guy but for heaven's sake, PUT A FORD in a FORD! The world has seen enough "cookie cutter" small block Chevys.
Old 04-13-2005, 07:39 PM
Max Keith's Avatar
Ford in a Ford
Amen, we have far too many Chevy powered Clonemobiles out there as it is.
Old 04-13-2005, 07:43 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
427 Cobra Jet
Mike
Old 04-13-2005, 07:44 PM
Early Iron or No Iron
Completely agree with the two previous,howzabout go one better and retain the flathead?Ya can't get any cooler than that.
Old 04-13-2005, 08:06 PM
segge's Avatar
Any of the above are good choices lol, but to answer your question go with the 351
Old 04-13-2005, 09:10 PM
tbirdscott's Avatar
stuff'n things'n whatnot
If you put a sbc in there it will burst in to flames before being sucked in to the depths of hell.
Old 04-13-2005, 09:21 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
any V8 ford will be appropriate.
Old 04-13-2005, 09:31 PM
stepside454's Avatar
its your car...do what you like..if it were mine it would be Ford powered...& im generally a Chebby guy
Old 04-13-2005, 09:36 PM
351,please.
Old 04-13-2005, 10:07 PM
Jared's Avatar
TPI engines can be mean but I tend to like 429-460 fords. My 429 in my bronco was even beating my SBC in gas mileage( I guess that 14 miles to the gallon isnt great but I didnt find it bad for a big block with a holley 750 on it.) Other wise I would go with the SBC TPI it will be better for cruzing if you plan on driving it, if its all show no go then yea I would build a 351 or the original flathead.
Old 04-13-2005, 10:16 PM
Max Keith's Avatar
351 or 350
Dont be dissing the 351W, its a very gutsy engine.
Old 04-13-2005, 10:37 PM
camaroman7d's Avatar
If you really want to get people going put a Mopar in it. You might get run out of town but it would be different.
Seriously it is your car don't worry about what others think. since you asked I am assuming you are concerned with the way others "see" your car. If that is the case go with Ford power in a Ford.
Either way you go someone will have something to say about it. If you go with Ford power people will say you are throwing money away (because they cost so much more to build the same power as a Chevy). If you go Chevy power then you are just a "follower", etc... Do what makes you happy. If you have the Chevy engine sitting there then use it, if you are starting from scratch and I were in your shoes building a Ford (that'll never happen) I would put a Ford in it. This is from a guy building a Buick and putting a Chevy in it (I already have the engine handy).
I think you will get more respect if you put a Ford engine in it (from the Ford guys).
Royce
Old 04-13-2005, 10:43 PM
Max Keith's Avatar
the end result
Well the ballots are in, and Camaroman is right. The final choice is yours.
Old 04-13-2005, 11:25 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Heavens
Put the ford in it..the distributor is in the correct end...
OMT
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
Bog/Black Smoke on Olds 350 at 3000 rpm JohnTN Engine 4 03-17-2009 11:39 AM
350 sbc in a 1951 ford 51FordDuff Engine 9 07-18-2005 11:10 AM
