-   -   1951 Pontiac 3 speed syncro (http://www.hotrodders.com/forum/1951-pontiac-3-speed-syncro-223599.html)
longhare47 09-01-2012 05:38 PM
I'm trying to find out if the stock 3 speed syncro trand in my 51 pontiac will match up to a small block chevy bell housing, anyonr kn ow anything that can help me????:mwink:
junior stocker 09-03-2012 04:02 AM
I belive 1958 was the first year for Pont to use the Chevy bolt pattern on the trans in bolting it to the bellhousing; so no, it won't fit/bolt on. Butch/junior stocker.
timothale 09-03-2012 06:36 AM
2 spd syc
I my memory is correct only second and 3 rd gear had syncronizers, Pontiac with a first gear synchro started in the mid 60's and were actually a 3 speed top loader they bought from Ford. Packard from Mid 30's Had a synchro on first gear,
RWENUTS 09-03-2012 10:25 AM
49-54 3 speeds had a different bolt pattern and don't swap with other chevy bellhousing mounts.
