1951 Pontiac 3 speed syncro - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2012, 05:38 PM
I'm trying to find out if the stock 3 speed syncro trand in my 51 pontiac will match up to a small block chevy bell housing, anyonr kn ow anything that can help me????
Old 09-03-2012, 04:02 AM
junior stocker's Avatar
I belive 1958 was the first year for Pont to use the Chevy bolt pattern on the trans in bolting it to the bellhousing; so no, it won't fit/bolt on. Butch/junior stocker.
Old 09-03-2012, 06:36 AM
Wiki Edits: 27
2 spd syc
I my memory is correct only second and 3 rd gear had syncronizers, Pontiac with a first gear synchro started in the mid 60's and were actually a 3 speed top loader they bought from Ford. Packard from Mid 30's Had a synchro on first gear,
Old 09-03-2012, 10:25 AM
RWENUTS's Avatar
49-54 3 speeds had a different bolt pattern and don't swap with other chevy bellhousing mounts.
1951 pontiac devondave Hotrodding Basics 3 07-08-2012 09:56 PM
1951 Chevy business coupe, replaced the 3 speed with a 4 speed transmission. EricKessel Transmission - Rearend 1 08-08-2011 09:35 PM
1951 Pontiac Front Clip?? Custom_Rods Suspension - Brakes - Steering 3 04-29-2004 07:11 PM
Pontiac 2 Speed paperairplane Hotrodding Basics 3 12-16-2003 09:47 AM
Pontiac 4 speed general Transmission - Rearend 2 11-06-2002 07:32 PM
