1951 Styleline, Looking to swap 200-4R for my cast iron glide - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2012, 10:54 AM
Low n' 51ow's Avatar
It's slow, not to low.....yet.
Last journal entry: 1951 Styleline DeLuxe
Looking into a 200-4R swap for my glide and going with a tri-5 rear. I understand the rear should go in without too much trouble. Anybody out there with suggestions for this? I know someone makes an adapter for the 235 to 200-4R. Some pics of a similar swap would be beneficial and some sound advice on avoid this, do that it will save you some time would be appreciated...
Old 02-13-2012, 06:16 PM
Wiki Edits: 31
Being you have the powerglide trans, it uses an adapter to connect it to the block. use that adapter with the 200-R4 and it will bolt up.. Just dont scrap the old torque tube glide. there few and far between now, and the powerglide rear is 3.73 ratio where as the stick is 4.11.. Stick cars can benefit from the higher gears with modern highways.. I have a '51 Fleetline 4dr, with the powerglide. Not too many got built like that
1951 chevrolet Styleline Deluxe ClassicDee Introduce Yourself 1 05-08-2009 06:42 AM
Which rear for 1951 Styleline GhostImpala Transmission - Rearend 1 03-27-2009 09:08 AM
1951 chevy styleline deluxe booster OC51CHEVY Suspension - Brakes - Steering 3 02-17-2009 11:40 AM
57 chev cast iron power glide need info rat_crazy Transmission - Rearend 1 05-30-2007 02:56 PM
Brake parts cast iron or cast steel brainsboy Suspension - Brakes - Steering 0 05-26-2004 04:42 PM
