1952 chev pickup questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2004, 10:22 PM
Hi all,
I'm start a '52 chev pick up project that has complete sheet metal but the orginal frame is gone...
My question are:
1) what is the stock wheel base for a 52 chev short box ?
2) what is the stock track width front and back.
I'm trying to sort out which newer frame is the best to put under the sheet metal.
Also I'm going to have a bunch of spare sheet metal left over. I think there is almost 2 complete truck in the pile. 2 cabs for sure.
Old 10-15-2004, 06:12 AM
Wiki Edits: 49
The wheel base is 116". When it comes to track width for the rear you'll need a center of tire to center of tire measurement of 63" and for the front something close to 59". The best late model rear for these trucks is mid 70's Camaro or Firebird. Some people like to use Camaro clips for the front suspension however the Camaro is a little too wide and just doesn't look quite right. A Nova clip would be a better choice. When it comes to replacing the entire frame the consensus of opinion is to use the S-10 frame and from what I've heard it's a pretty good fit.
Centerline
Old 10-15-2004, 07:31 AM
Keith Boisvert's Avatar
I agree with Centerline. I have a 53 with a 81 Carmaro front clip. Works good, but if the truck hadn't come that way I would have used an s10 frame. I have a complete How-to on doing the frame swap to an S10 somewhere if you need it let me know.
Old 10-15-2004, 11:12 AM
I'd highly appreciate it it you could send the S10 how to.
thank you !
Old 10-16-2004, 10:07 AM
Tazz
Man I could have used that info a few years back!!!
Tazz
Rat Rods Rule!
Old 12-12-2004, 02:23 PM
s10 swap
hello can u email me the info on the s10 frame swap thanx chance1@comcast.net thanx
Old 12-12-2004, 10:59 PM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
Or how about sending it to Jon so we can have it in the knowledge base.
Old 05-28-2010, 08:28 AM
Last journal entry: 54 hhr
52 Frame
USE A REG CAB LONG BED 117" W.B. S-10 AND USE A REAR END FROM ANY S-10 4x4 &2" WHEEL SPACERS IN FRONT. EZ SWAP
Old 05-30-2010, 02:57 PM
Wiki Edits: 49
Try looking at the date of the thread. This one is 6 years old!!! I think he's solved his problem by now.
Old 05-30-2010, 04:25 PM
65ELCMO's Avatar
I know this is old but if that how to is still available I sure would like to get it. Thanks, Steve
Old 05-30-2010, 09:39 PM
There is a how to over on the 67-72chevytrucks.com forum. Has schematics for the brackets and everything.
EZ Chassis swaps sell the complete kits, But they are kind of pricey around $1300
Shane
