1952 chevy 3600 swap to 95 ext cab s10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2013, 10:29 PM
I'm looking to put my 52 on a 95 s10 frame its ext cab and I've been hearing its the cheapest easiest way to go. I've only helped and talked to people that did the late 80s and early 90s model s10s anyone have more info on this style Swap and what I could use for a newer style ac and heat?
Old 01-22-2013, 08:18 AM
Wiki Edits: 27
chassis swap
I've seen kits offered for around $ 1000, I don't know what years parts were used. Some chassis swaps are easy others are a real pain. I would carefully look at one THAT has already been done, rather than believe someone that says it' is easy. Usually it's easier to keep the stock frame and upgrade the suspension. We did a 48 Jeepster on a 78 blazer 4 X 4, it was about 4 times as much work as I was led to believe.
Old 01-22-2013, 02:58 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Advanced-Design Engineering S10 Frame Swap for AD Trucks
s10 ext cab roll bar lsxtreme General Rodding Tech 8 01-02-2013 02:45 AM
93 chevy c/k1500 ext cab V8 5.7L 2dr tbi cruise control bry1914 Electrical 0 12-03-2012 12:32 AM
01 s-10 ext cab convertible? dustinmishlerrr Body - Exterior 2 05-01-2010 03:56 AM
1952 Chevy 3600 rear end Crakums_GT Transmission - Rearend 15 12-12-2009 07:35 PM
