1952 Chevy Fleetline brake lock up - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2003, 12:02 PM
Dawger's Avatar
Talking 1952 Chevy Fleetline brake lock up
Hello all
On the fourth of July I was on my way to a friends house for some festivities when some no brain waited for me to aproach the intersection then proceded to pull out in front of me. Not wanting to marry my Fleetline with a Toyota I hit the brakes hard and aimed for the shoulder. After returning to the road I noticed that my brakes were dragging. I then tried the emergency brake thinking this may unstick them. BIG MISTAKE. This locked them up completely and my car was unable to move. I managed to get back home by jacking up the car and releasing the brake bleader. Fluid came out under high pressure.Imade it home but both back brakes were smoking hard.
I have since taken both back wheel cyclinders and master cylinder apart and cleaned them. no change. The brake shoes seperate but do not return to the post. The only thing I can think of that may be causing this is somthing in the line acting like a check valve. Next I will try blowing air through the lines.If anyone has any suggestions please reply.
PS. the car has stock drive train. (for now anyways)
Thanks so much Dawger
Old 07-08-2003, 01:02 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
also check the rear brake hose, it could of collapsed on the inside..joe
Old 07-13-2003, 11:37 AM
Dawger's Avatar
Thanks so much joe.
After reading your post I went ahead and got a new hose. Just got around to installing it .did the trick
Thanks again.
Old 07-13-2003, 01:02 PM
Wiki Edits: 5
glad it helped. I know when my brakes acted up & I havent changed the brake hoses yet, they are one of the first things to be checked & by changing them you're just giving yourself some CHEAP INSURANCE & extra saftey..............joe
