1952 chevy fleetline rearend replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2012, 09:50 PM
Good evening to all, im restoreing a 1952 chevy fleetline and would like to replace the rearend, i have a 69 camero for it but was told it would be to wide for fender skerts, ???
Jesse.
Old 06-17-2012, 10:18 PM
RWENUTS's Avatar
Measure your original and pick a rearend from this chart.
http://www.myspace.com/bomberscarclub/blog/481908067
Old 06-18-2012, 07:12 AM
Wiki Edits: 27
centering
Be aware that the spring center bolt is offset on old torque tube rears. you either need springs with the correct location bolt for your new rear end or an offset adapter bracket if using original springs. to center the wheels in the fenders
1951 chevy fleetline lethal lily Introduce Yourself 1 01-02-2009 08:35 AM
49 chevy fleetline dj153727 Introduce Yourself 3 01-21-2008 06:31 PM
49 Chevy Fleetline rockabillykid92 Engine 4 01-03-2008 03:03 PM
Chopping a 49-52 Chevy Fleetline RDavid Body - Exterior 4 06-23-2006 05:47 PM
1952 Chevy Fleetline brake lock up Dawger Suspension - Brakes - Steering 3 07-13-2003 01:02 PM
