#1
Hi all,
I have a 1952 Chevy Sedan Delivery that has had a 500 ci Motor W/ Automatic Trans. put in to it and no other upgrades that I can see. This is my first project car. I am looking to use it as a driver and I am not hard on vehicals (My 1990 work van has 382,000 miles on it) - I just want to ride in style and turn a few heads. I am looking for sugestions - I am thinking about a MSII front end kit. Any sugestions would be very helpfull. Thanks all Register now (free) or login to remove ads |
#2
I assume your 500incher is Cadillac from the 70s. Maybe the best thing for this car would be a 74 NOVA clip, this gives you power disc brakes, rear mounted power steering box, and off-the-shelf parts availability for the road.
#4
I'm working on a'46 Chevy panel right now. It has a 350/400T set-up. The guy that had it before me put S-10 arms, springs and stuff on the front but that is all comming off(hopefully this weekend) and a Mustang II kit is going on. The S-10 stuff just won't work, I tried getting a rack for it and that was a waste of time, none will fit. I thought about going to stock S-10 steering and found that by the time I got all the parts needed it was almost as much as the kit. When I get it changed over I'll send you some pics if you'd like.
David [ January 21, 2003: Message edited by: Bluepen ]</p> |
#5
I would go with the MustII setup. There are a couple of other potentials. You could use a Volare front clip and get the torsion bar set up. The width would be about right and is frequently used in narrower trucks. You also can use a front steer first generation Camaro/Chevelle from '67 to '69. These are a little wide but can be narrowed 3" with the Fatman narrowed A arms. Since you are already modifying the motor mounts, I think the Mustang would be the best choice and offers the most selection of brakes lug nut patterns etc.
#6
Thanks for the input everyone - Bluepen if you could send me the pics that would be great - I have never done anything like this befor so any help is appreated.
I have done body & motor repair work but never suspencion remodleing. Thanks Again |
#7
ms 2 front suspension
hi,
i actually sub framed my sedan delivery with a 69 nova rear steer front clip...it is my understanding that the car might be too heavy for the mustang 2 brakes and suspension. |
#8
52 Chevy
I had a 52 Chevy. It sat on a 79 Impala chasis and fit perfect. The 52 is a wide car and the mustang II just wont work. S10 is to narrow as well. I think you will have to go with a mid to full size clip on the front.
#9
Guys... This thread is 5 years old.
#10
52 chevy
if your 52 is anything like my 51 chevy u can find a bolt on front disc conversion on ebay for it and the rotors and cailpers are for 70-78 camaro to have power brakes walton fab can set u up with a power booster that mounts on the fire wall easy set up also check out kanter they have thicker sway bars for front and rear and if u want a mustang 2 front end check out jim meyer fab they have a bolt in mustang kit if u have the stock motor if u run the big block there will be a little mod to it to fit the big block
