1952 Chevy Truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2009, 07:34 AM
Last journal entry: 1952 Chevy Street Rod Truck Build
1952 Chevy Truck
Anyone built a 1948-1954 Chevy Truck with 350 ci and 350 turbo, mustang rack and pinion. What steering column will work best??? Thanks.
Old 03-19-2009, 04:55 AM
They're getting kind of hard to find but, a column out of a 70's Chevy van works well. The one I used didn't have an ignition switch and was a tilt. I got mine at the local junk yard for $15.
Barry
Old 03-19-2009, 09:39 PM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
I used a tilt, column shift unit from an early 90 S-10/Blazer with good results. the mounting collar bolts to two holes under the dash lip. It is reinforced back to the firewall mounting plate for the swing pedal mounting. The lower end of the column is secured using a muffler clamp welded to the firewall mounting plate. I can send you some pics if you need them. If you are not using a swing pedal though it may not help you much.
1952 Chevy Truck Chop chevy bb 572 Body - Exterior 2 09-12-2007 06:39 PM
350 chevy into 1952 Chevy truck reeves79 General Rodding Tech 3 07-07-2007 11:45 AM
1952 chevy truck silveradoman Introduce Yourself 1 05-14-2007 01:00 AM
Car 235ci into '53 Chevy Truck New2theart Engine 8 10-17-2006 12:37 AM
1967 Chevy Truck Gear Ratio 53chev Transmission - Rearend 3 01-27-2005 07:49 PM
