1952 Chevy Truck Tranny question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-24-2013, 10:27 PM
No problem Killer.
  #17 (permalink)
Old 07-25-2013, 01:42 PM
Had a schwaginaw come in the shop; 2.85 1st w. OD. OD will work on any Sag 3spd; but realistically, you want a numerically low 1st gear, to allow for the high axle and not drop your RPMs too low. Say a 3.7 w. the 2.8 1st and the OD. Life would be sweet.
  #18 (permalink)
Old 07-25-2013, 08:56 PM
I've been told I can get a RE from a 4x4 Blazer or S10 that will be an easy bolt up without a driveshaft or any other mods. I've found one from a '97. Does anybody know if it's really a simple remove one and bolt up the other swap as I've been told?
  #19 (permalink)
Old 07-26-2013, 08:49 AM
RWENUTS's Avatar
DEfine easy!
You'll need a different u-joint, possibly shorten the driveshaft, move the spring perches, new shock mounts, emergency brake cable brackets and then it might fit. You'll have 5 bolt wheels on the back and 6 bolt wheels on the front too.
Blazer rearends come in 3 widths.
S10 2wd--54".
Blazer 4wd---58".
Blazer ZR2---62".
Have you driven that truck yet?
  #20 (permalink)
Old 07-26-2013, 03:16 PM
OK. Just got home after being on the road all week. Truck was delivered yesterday. Yes I have driven the '52. No I have not driven the '97 Blazer if that's the question. Here's another curve ball. As soon as I got home today I looked under the truck and noticed the drive shaft is not open. There are no visible U-joints. Now it's looking like more work already. I assume that would mean a drive shaft change at the very least. Does that mean a tranny change also? I think it's time to call my mechanic
  #21 (permalink)
Old 07-26-2013, 03:32 PM
RWENUTS's Avatar
I wasn't sure if it would be a closed driveshaft considering the tranny change. So yup you'll need to change the tranny too. Unless you find an adaptor to change out the output on the tranny. I've seen them. Don't remember who makes them.
Patrick's might know.
Looks like a rear gear change is in your future.
What I meant by having driven it yet is you might like to leave it alone once you drive it.
1952 Chevy Truck..4 Link question. j_johnson Suspension - Brakes - Steering 1 02-09-2011 11:37 PM
1952 chevy truck with a 454 52truck General Rodding Tech 1 01-29-2010 10:36 AM
1952 Chevy Truck NickO Suspension - Brakes - Steering 2 03-19-2009 10:39 PM
1952 Chevy Truck Chop chevy bb 572 Body - Exterior 2 09-12-2007 07:39 PM
1952 chevy truck silveradoman Introduce Yourself 1 05-14-2007 02:00 AM
