1952 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2011, 08:36 PM
1952 ford
Hi I just got a 1952 Ford coupe customline it has some rust alot of rust on the floor pans.ok here's my? What kind of sand paper to use to get her to bare metal I will be useing a dual action sander I here 80 gritty but use good sandpaper but what kind of sandpaper and what brand
Old 05-14-2011, 10:34 PM
JeffB's Avatar
I like the Norton 36 or 40 grit discs from our local Sherwin -Williams auto body supply.I moderate a 580 member 1952-56 Ford group on the HAMB,these Fords are known for rust in the floor pans and replacement floor pans are now available thru ebay and several suppliers.Look under the rocker panels and the drain holes may be plugged it is not a bad idea to enlarge them for better drainage,if you have the door panels off you will be surprised at the crud you will find in the bottom.A lot of the dust and dirt comes from the "fuzzies" around the windows being worn out and it settles in the door bottoms,I filled three buckets from my Arizona car plus what went in the 6 HP shop vac.The floor pans on the pass side tend to rust from heater core leakage,so check that area also.
1952 ford pickup guy 1952 ford pickup guy Introduce Yourself 4 10-13-2009 02:27 AM
1952 Ford F-6 question greasemonkey383 Hotrodding Basics 3 06-20-2008 12:05 PM
1952 Ford ERNIE GUERIN Introduce Yourself 1 10-07-2006 05:24 PM
1952 Ford Pick_up EDKEELEY Introduce Yourself 1 03-09-2006 04:53 PM
1952 Ford F-1 Truck our52ford Hotrodding Basics 6 08-27-2005 01:03 AM
